Hi we using wildfire 5 creo elements, in the present scope of work we need to create 2 sheet in the drawing. where we are trying to copy the first sheet view and dimension to second sheet which is creating problem
nitagi
2-Explorer
Hi
kindly help us to overcome this issues.
2 REPLIES 2
BenLoosli
(To:nitagi)
What sort of problems are you having?
If you have shown dimensions, they will not copy as that makes your part double-dimensioned.
nitagi
2-Explorer
(To:BenLoosli)
what every views and dimension are present in the first sheet of the drawing, I want to copy them to second sheet, because I want both the sheet to took same
