High resolution image export in Creo Illustrate?
slilja
Hi, I would like to export high resolution images from Creo Illustrate but it doesn't work properly as expected. It says "failed to generate image". Is there a workaround for this problem? I've noticed that it's possible from other users/computers that have tried this. They managed to export images in any resolution such as 600 dpi for example. I only manage to export in 160 dpi. That's not good enough.
Kind Regards Stefan
0 REPLIES 0
