Hole Note Refinement
wbottis
Hi Folks,
Using Creo 7.0.8.0
In the 'Shape' sub-tab of the 'hole' modeling feature ribbon, I recall the graphic used to show the tap-drill depth. I don't see this anymore. Nonetheless, is there a way to add drill depth to the note callout properly? This is omitted and only tap-depth is shown. Thank you.
BenLoosli
(To:wbottis)
Creo 9.0.9.0 shows what you want for the note, but not graphically.
pausob
(To:wbottis)
At some point, the GUI changed and now the tap drill depth is specified elsewhere:
It seems the reason your note doesn't show it is because you are using a custom hole table (UNC-2B_RTN ?) that has a callout definitions that do not display the dap drill depth...
Hi @wbottis,
Anurag
