How to analyse a vibration test table?
Durbal.Andrew.H
Is there a way to analyse the interaction and resultant displacement and stresses between a model sitting on top of a vibration test table?
I have an assembly with 2 parts in, one to represent the test table and the other to represent the model sitting loose on top.  A vibration profile of the forces are applied to the test table part with contact interfaces (with friction) defined between the 2 parts.
When I run a modal and dynamic frequency analysis, it shows that the contact interface between them is ignored and they will be free.  The same error occurs when I define a non-linear static analysis.
Is this possible to define with such a motion and analysis in CREO or not?
Durbal
0 REPLIES 0
