How to convert the assembly model in shrink-wrap as per model tree and assembly sequence with naming.
I need to convert the assembly into shrink-wrap but it coming in external copy geom with no naming and sequence is disturbed.
Can we have any solution (like .step file conversion)?
You have not mentioned what version of Creo you are using.
This is what you are looking for, new in Creo 11.
Multibody Support in Shrinkwrap Feature
