How to find failure load?
JohnDoe
2-Explorer
Does anyone know if there is a way to find the load that will cause a part to fail? I have the yield stress and a specific spot where the force is acting, but I cant figure out if there is a way to get the maximum force it can hold. Thanks
SylvainA.
(To:JohnDoe)
It depends on your material properties... With Pro/Mechanica, you can find the maximum Von Mises stress. If it is greater than the ultimate strength of your material your part will probably break. The way I like to do this is to start a Pro/Mech analysis, then display Von Mises results and use "Info>Model Max" in order to find the maximum stress.
