Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
I have detail that I need to re-engineer on this part. Ideally I would like to create a boundary blend including the light blue line as one of the boundaries. The problem I'm having is that I'm not sure how create a spline that will connect the light blue line to the dark blue surface. The vertical black splines do not intersect with the light blue line.
-- Carl Lever Yorkville Sound TEL: 905.837.8550 ext. 222 FAX: 905.837.8746 clever@yorkville.com
