How to run mapkey only for part?
Gucio
Hi all,
Any idea how to allow to run mapkey only for solid part? Imagine that mapkey adds annotation feature. This mapkey should only works for solid models, for sheetmetal and assemblies is should be forbidden.
Because I'm able to sort files, and select only necessary -I've try to use ptcdbatch, in which only solid part were selected, but unfortunately this functionality does'n work( look at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS109444).
Maybe there is an issue with my mapkey definition.
regarsds
Krzysztof
Krzysztof
Gucio
(To:Gucio)
the issue was with definition of mapkey.
At the end I forget to add
mapkey(continued) ~ Command `ProCmdModelSave` ;~ Activate `file_saveas` `OK`;
Krzysztof
