It is difficult to determine what the error is remotely. Here are my thoughts:
I don't believe this will change the font already created. That will have to be done manually.
Thanks for your reply, I config the creo as your steps and it doesn`t work, because it will rollback to default after I change the "default_annotation_font" value and then close the "Detail Options" page, that`s strange.
It seems to work for me in Creo 7.0. The only suggestion I can give is to ensure that you "Apply" the settings in the detail options then save the drawing.
Hello @WX_12788011,
It looks like you have some responses from a community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
