1. i have a font iso3098_3 being used in catia by my clients, so is it possible to get this same font in creo parametric 3.0?
2. the center line should be the same as that of line type 4, thickness = 0.13 mm and color red as that of catia
3. the section line of line type 4, color black and thickness 0.35 mm as that of catia
4. dimmed lines as line type 1, color green and thickness 0.13 mm as that of catia
5.detail view circles and profiles as line type 5, color green and thickness 0.13 mm as that of catia
the most important is the first question.........
You can add fonts to creo by placing the ttf file in the folder <loadpoint>\Common Files\text\fonts\
For the other question about line thicknesses and colors, search the community or help for pen table files.
