IFX in Creo 10.0.4.0
When using IFX it standard creates holes in modifiable parts. When you don't want that you have to set it manually each time to "Do not create a hole".
Is it possible to have it default always set to "Do not create a hole" for all parts?
you can change the IFX-option HOLE_VISIBILITY in General Configuration Options
If set to 'NO—Do not create a hole.' no holes are created any more.
A little late but: thank you!
O no sorry, I meant my response to your solution was a little late!
Thanks again!
Ok - sorry for this confusion.
I thought you mean my post and I wonder if you have received it recently.
