Also, if the original assembly was exported from PROE and the parts were
of different units, your import will assembly incorrectly. When you
send out STP you have to be careful about the units. It's easy to miss
sometimes if you're using parts from other sources or previous projects.
-Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
