In Drawing - Hatch Selected Surfaces
I want to designate portions of a part or assembly, by hatching, to be treated with a particular finish or inspection criteria.
Example: Imagine a drawing of a soccer ball, with the black patches hatched. A note on the drawing says HATCHED AREAS TO BE PAINTED WITH BLA BLA BLA...
It would be nice to designate surfaces in the model, or drawing to be hatched in the drawing. The hatching should be scaled and oriented within the drawing, but the selected geometry should be from the model.
The current method is to sketch a perimeter, piece by piece, until you have a closed entity which can be hatched. This is madness, especially when when working with complex styled surfaces. The perimeter does not update if the part changes, and it may consist of hundreds of entities. Another method is to create a hatched sketch in the part show the sketch in the drawing. This is a little more parametric, but the hatch spacing parameters have no relation to drawing units and still tedious.
If I could simply select surfaces and they would appear hatched, it would save our company thousands of hours per year.
