Including Cable/Harness Parts in Shrinkwrap of Assembly
Blue_Oranges
Hello! I'm working in Creo Parametric 10.0 and I'm having some issues with Shrinkwraps. I'm trying to export large portions of a somewhat complex vehicle to STEP format for sharing with vendors. As our vehicle has become more complex, this has driven the need to share lighter-weight CAD with vendors, as exporting any top-level assemblies as-is (even with significant part reduction via simplified reps) can take hours. And importing the resulting step files takes even longer, and I don't want our vendors to have to deal with the ridiculous load times on their end.
So, I've taken to shrinkwrapping, then saving those shrinkwraps as STEP files to share with vendors. This reduces export file size and import complexity, but one issue that I'm constantly having to workaround is our numerous harness/cable assemblies not making it into the shrinkwraps. This means I need to have our full harness installations (with connectors/backshells) included while saving the export, which massively slows down the export process and really kills the time-savings I've gained back by shrinkwrapping everything else.
Key Question: is there a way (besides saving all of our harness separately as a huge STEP file) to have cables included in a shrinkwrap? I guess I don't understand why they aren't able to be shrinkwrapped by default, since harness is a pretty significant part of assembly packaging, and should be reflected in any sort of scenario where you want the physical parts that need to be designed around to be present in the model export. Regardless of whether or not cable features are just cosmetic, they represent a physical aspect of the final product, and since shrinkwraps are commonly used in envelope representations of large complex assemblies, I'd assume they can be included in shrinkwrap features.
Any tips? Thanks!
Per CS41458 it is not possible and there are no plans to fix. You could open up an idea for it.
https://www.ptc.com/en/support/article/CS41458
Your best bet would be to export the harness as a separate step file with the cabling surfaces. You might be able to import the shrinkwrap and the step file and then export that combined file back out as a single file.
