We facing some problem in Pro-E. We can not able to check the interference of the part at the final moving position of the part. Ex - I designed a plate and i designed a Bush , In normal condition these 2 components have a 30 mm gap, But while the plate is moving it is inteference with the Bush. which we can not able to check or predict in the software...Is there any solution plz expedite...
Exploded views are static representations and cannot be used to find interference.
If the part has mechanism constraints then you can set interference detection which will stop the part when it runs in to another part when you drag the mechanism.
