Interesting Observation - Offset Features
TomD.inPDX
I was using an offset feature to resemble a weld between a tube and a bracket.
The features looks well enough in the model but there is a strange issue with and Offset feature... it doesn't merge with intersecting solids!
Here is the feature itself:
Funny thing is, you can trim with extrude across the feaure and remove material.
So I had to cut and refill the feature. This worked okay here but was not nearly as simple in another region.
As persistent as Creo solid models are about merging solids into a single solid part, it is odd that this particular case is ignored.
This is in Creo M040. I will probably send in a case with support on this in the near future if it is still prevalent in M070.
Have you run across this?
9 REPLIES 9
I have attached a quick sample file of the issue:
Hi Tom,
Yes this is strange. I have not used Offset in this way. I have used it countless times to do a simple offset of a surface (or quilt) and have also used it to replace a surface (but quite a while back so do not really remember it).
Essentially I found I did not understand how the other two choices in Offset worked so I did not use them.
In the example case you show it makes a solid feature but does not recognise the intersection with the other leg of the solid. It is as if it has made a surface feature but filled it from below with the surface boundary remaining in the other solid as it would if it was surface only. This is M060
As a complete change of tack how about a projected curve as the base of your weld and a sweep (for me VSS) to give the inclined wall and then use solidify? Very robust. If you are really keen you can copy the surfaces of the tube and the block then merge these to your sweep to get a surface volume which you then solidify but unless you need this volume for something it may be over the top.
Regards, Brent.
Solid should find their own intersection,offset feature is like cross between surface and solid maybe that's why.just guessing.
also sometime i find need for "select offset upto or hold shift to catch the point/surface" while offsetting a curve on a plane instead of giving actual measurement.
I reported it to customer service. We will see what they have to say.
I thought of a couple of ways to do this but it is a simple representation. Extrude-cut through it and refilling fixed it, but just seemed weird to have to do this. It really is a neat trick to show a weld, don't you think
In the original example, the weld is on a bend in the tube, and it is not normal to the surface. It wouldn't even let me wrap a sketch onto the surface. I had to offset the surface by zero and trim it with a revolve surface to even get an edge to sweep along. Of course, the weld feature didn't recognize this as a valid connection either.
This is how you get corrupt solids as exports. Not acceptable!
Of course... if we -wanted- to be allowed to do this, we couldn't
you are right about weld,nice weld you got there.I was thinking if round feature could be used to fill the gap.
Yes offset should find the intersection like solids.
You are right... when I interfere the surfaces, I can use chamfers and rounds without issue (found the "tangent distance" option! Nice.). In this case, the flat plate just sits on the tube. As for the single solid, it is joined at the other end of the flat plate to make is all one solid.
This issue has been submitted as SPR 2192810; stay tuned.
Today I received a reply.
The R&D explained the functionality as,
These offset features (expand, with draft) DO NOT INTERSECT. It is up to the user not to drive the offset through existing geometry.
This was not raised for the first time, and there is a note in the Documentation about it.
Take it for what its worth. I find this totally bogus as I -want- the surface to intersect and merge!
