Hi Stefan!
Uh-Oh! It seems that you are experiencing the Dreaded (and inscrutable) "Oracle Cannot Connect to Server" error... I used to get this on Intralink 3.4 client machines (with both build M030 and M070) occasionally. I never was able to track down the source of the error - my fix was to have the user reboot & I seem to recall this always worked.
Another possibility that occurs to me is the clinet "tnsnames.ora" file may still be referencing the original server. I don't have an Intralink 3.4 client installation to look at anymore - but I think I have the name correct, and the file should be located in the "proiclient" installation folder, I believe...
Here are a couple of useful (?) links that might also help:
http://www.mcadcentral.com/creo-data-management/7731-oracle-c-nnect-failed-3-4-m011.html
Finally, check TPI #124157& #103537 on the PTC tech support site for info related to this error - but again I never found the source of the error.
Good Luck!
Mark Kelley
In Reply to Stefan Mueller:
Hi all,
For anyone still on Intralink 3.4
Ever see this error message? And if so, what does it mean and how to correct?
Appeared after a server was relocated.
Stefan
[cid:image001.png@01CE4907.27475CB0]
