I have a problem with assembly. The thing is, completed parts are not visilble in assembly. They are imported to assembly and do show up on the model tree. Some of them do show up, whereas others don't and I can't find any way to resolve this. I would be thankful for any help.
Kamil,
all 3 parts you have put into the assembly are displayed, when I open the assembly. You can't see kolek_61.prt and podstawa_11.prt because these parts are very small when compared with jarzmo_11.prt.
Try to zoom in your assembly to see small parts.
jarzmo_11.prt ... height = 703.943 inches
kolek_61.prt ... length = 14 inches
podstawa_11.prt ... size = 800 x 480 millimeters
Martin Hanak
I have only had this happened when I accidentally leave a part with curvature analysis turned on.
Another way can be if you have your graphics set course where small parts at a greater zoomed out state are not shown.
Kamil,
check layer status and layer contents. if it is possible, upload some example.
Martin Hanak
I haven't used any analisys at all, included curvature. Sorry, Martin, but how do I "check layer status and layer contents"? I have uploaded an example as you asked.
Kamil
Kamil,
Martin Hanak
Oh my... Different units - that's the issue. My bad. Thank you for your help.
Kamil
