I'm using Creo Elements/Pro 5.0. When creating drawing views, I tried to change scale of a projection view, but the scale option is greyed out, I can only change the scale of the parent view. In SolidWorks, it is very easy to do this, just right click on any view and change scale.
EDIT: Just change the View Type to General. Remember to remove the Alignment to the original view if you need to move it.
That works. Thanks!
You are welcome. ![]()
