When i start drawing in 3D i get alot of lags in the program.
I also got it when i make 2D drawings
It also says program does not react.
I re-installed this program, the first time when i installed it i didn't had the lags i only got it the second time i downloaded it.
Is there anything that i can do to this?
Thanks in advance,
Jov
Hi Jonathan,
I see that you didn't get a response on this thread so I wanted to bump it. Are you still having the issue?
If so, here are a couple of questions I have:
Is the problem occurring for all models and drawings or is the lag specific to a particular model?
Are you saying just the creating of a new drawing is slow?
When you create a new drawing with no template and empty (without a model) is it still slow?
My first guess is that you might have your format or template files on a drive with a poor network connection.
