I'm on WF4, M190, and I;ve had problems where sometimes the layer rules work, sometimes not. For instance, I've set up a rule in my datum planes layer to put all datum planes there, unless they are the 3 default or GD&T datums (filtered out by name, i.e.: SIDE_X, N_(name), A, etc.). For the planes and other things, it works fine. For surfaces, and datum curves, it doesn't. Has anyone else seen this?
Still seeing some odd behavoir. In playing with it more, SOME of the rules don't like the line: "Name != N_*". So, I tried: "Name != *" and it worked......in those case I was having issues anyways, the rest work fine. Weird........
Frank,
upload your data and describe the contents of layers. I can check your layer rules.
Martin Hanak
