Hello everybody,
I would like to create layers within layers by rules in order to finish a template.
The problem is that I can't find the right search for creating the rules...
As "Layers" is not part of the standard research , do you have any idea to solve it?
Thank you in advance !
Romain,
What items are you trying to add to the sub-layers? and what is the main layer, does it contain rule?
For example I would like to add with a rule different inheritance layers to the main layer named "inheritance"
Romain,
See attached snapshot and try.
I tried but it is not working.
It is not exactly what I am looking for. You proposed 3D curves while I am looking for layers.
I realy need to create main layer which is composed of others inheritance layers.
When I hide the main inheritance layer, the sub-layer inheritance must be hidden
