Looking for Config.pro options
GregMerz
7-Bedrock
Wildfire 4.0:
Looking for config.pro options:
1) To set the model display shade quality, default is 3 (View/ Model Display/ Shade/ Quality
2) To turn off the tolerance display in the model (not drawing) (View/ Model display/ General/ "uncheck Dimension Tolerance"
3) In the model tree, is there away to not have the "Feature #" column cover up the feature names? "Feature #" is set to 8 wide.
Can you set the first column width?
Hi
is controlled through config option
shade_quality
This option is introduced in WF-5
Regards
K.Mahanta
to 2.)
tol_display NO turns off the display in the model (may be drawinbg also) ifg so look at the drawing.dtl file to turn it on there
to3.)
turn the column of (tree settings- colomns and slecet column NOt to display)
save the setting into a file.
Retrieve those setting as standard by adding
mdl_tree_cfg_file path and filename to your settings file
e.g.
mdl_tree_cfg_file D:\usr\people\weber\Work\tree.cfg
into you config.pro
