Losing surface properties while regenerating a file.
ptc-5120029
I have a customer using wildfire 5.0 and he uses parameters to generate different versions of his parts. There's a main parameter (call it "Size") and every other parameter depends on Size, every "dimension" is calculated based on parameters.
The problem is that when he regenerates his parts by changing the main parameter, everything goes well, except that surface colors and properties (like "Surface Name") are lost. We need to keep the properties in every version to be able to identify each surface individually. I'm not used to Wildfire or Creo at all and i'm pretty sure this is possible.
My question is simple, what's the solution to keep colors and properties used in the "generic" size of the part when regenerating the part ?
- Max -
0 REPLIES 0
