Manikin field of view problem
I am reposting this issue as the prior posting linked to a help document that apparently isn't accessible to customers.
FOV of the manikin view window seems to be randomly changing. Sometimes the manikin FOV window shows a more narrow FOV (maybe just the non-periferal?) and then randomly sometimes it will show a wide FOV.
Sometimes this is triggered when you move the manikin. Other times, seems random.
I am in CREO 7.0.8.0
thanks all
prior thread on this topic "solved" with a locked out article: https://community.ptc.com/t5/Creo-Modeling-Questions/Manikin-field-of-view-problem/m-p/395453#M117108
"solution" to prior "solved" topic which is a locked out article:
