Mapkey to search for a param, change type and add data
jhengel
Hello all,
I'm hoping someone can help me. I'd like to create a mapkey to search for a part number within an assembly, change a parameter property type to Integer and then ask for a value to fill in the Integer.
I'm using Wildfire4 by the way...
Thanks!!!
John Hengel
davehaigh
(To:jhengel)
You can't change the type of a parameter after it's created. Once it's set to string, or some other type, you can't change it.
David Haigh
You could do this task through one of the programming toolkits. Like
Pro/TOOLKIT or J-Link.
Bob Monat
Jerand Technical Services, Inc.
Bob Monat
bob@jerand.com
www.jerand.com
1-317-875-6087
nuheht
(To:jhengel)
I do something very similar to that, however I created a trail file to accomplish removing parameters, adding parameters, and the trail file ends leaving the parameter window open so I can enter text as needed.
I do something like that with component parameters, with a JLink program. I search for a parameter, read the value, delete it and recreate it as integer, then designate it.
Best regards
Daniel
Enviado desde mi iPhone
> El 17/12/2013, a las 18:00, John F Hengel <-> escribió:
> Hello all,
> Thanks!!!
> John Hengel
> Site Links: View post online View mailing list online Start new thread via email Unsubscribe from this mailing list Manage your subscription
> Use of this email content is governed by the terms of service at:
