Mechanism Connection Question
ShandRonnie
6-Contributor
I need help to create a mechanism connection to keep the bucket of an earth moving machine parallel to the ground.
When I use the pin connection I get the axis and translation option, but the translation option does not have an orient. It aligns/mate the 2 planes to be coincident.
I cannot find a constraint to orient the bucket so it is always level to the ground as the boom arms move up/down/forward/back
Any help would greatly appreciated.
Ronnie
2 REPLIES 2
Ronnie,
Use geometric constraints i.e. plane to plane
Cordially,
Dr. Andreas Vlahinos
Advanced Engineering Solutions, LLC
4547 N. Lariat Dr.
Castle Rock, CO 80108
303-814-0455 Office
720-838-0455 Cell
I got the answer back from PTC technical support.
The solution to get the orient option is to use the "General" mechanism constraint.
Thanks!
Ronnie Shand
