I know this post is very old, but I found the following information on a PTC case.
Title | Error “The Model is disconnected” when working with assembly in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric. |
Description |
Applies To |
Cause |
Resolution |
Hope it helps anyone!
Description |
Applies To |
Cause |
Resolution |
Ana-
Your post was the solution for my situation with a "Model is Disconnected" error.
I had this problem with I had a few parts connected by a pin joints with both angles restricted. When I removed one of the angle restrictions and made the other parts not able to go perfectly vertical / horizontal my problem cleared up. I'm not 100% sure which thing fixed it, but there's a solution I had.
