ModelCHECK: Optional Parameters
N.Barnes
I have a ModelCHECK use case where some parameters may or may not exist.  I have discovered that if I only list the name of the parameter, then ModelCHECK will not report the parameter as "extra".  But if I add extra requirements to the parameter in the .mcs file then ModelCHECK considers the parameter as "required."   I would prefer to continue to check for "extra parameters" as defined in the conditions file.
Can I define the con which is.   "If the parameter exists then it must be a string"
In this case "the parameter may exist"
PRT_PARAMETER NOTE
In this case "the parameter is required and must be a string"
PRT_PARAMETER NOTE STR
Hi @N.Barnes
There is no direct option just to check the parameter type, if we use PRT_PARAMETER PARAM_NAME STR EQ *, it will check the parameter and type but create a conflict with existing value of parameter. for example if a parameter "NUMBER" is of real number type with some defined value, when converting it will conflict with string  and may not output as expected.
Thanks.
N.Barnes
(To:N.Barnes)
Spelling Correction:  Can I define the condition which is  "If the parameter exists then it must be a string"
Hi @N.Barnes
Thanks.
