I had heard before that when you see this result in ModelCHECK its because you have to many for it to count. Has anyone seen documentation on this issue?
Dear Scottb,
Kindly go through the link http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/model_analysis/checks/std_dtl_setup.html
Bharath I have the description, but I need to understand why the result says error. Us ally it give you a number, 1, 2, 3 etc
Hi, Found any solution for this?
Yes I have, we had an old Unix path pointing to one of our files.
Old
STD_DRW_DTL_FILE text/drawing_setup.dtl
New
STD_DRW_DTL_FILE text\drawing_setup.dtl
