Is it possible to allow drawing without formats while using the ModelCheck DRW_FORMAT option? The documentation says that "If the drawing does not have a format, Creo ModelCHECK prompts you to add one." but we sometimes create DXF sheets or DXF drawings that don't have a drawing formats. I was currious is anyone figured out how to allow for a drawing or drawing sheet to have no format without hitting this error.
Setting DRW_FORMAT will force to add format. No option to skip. I dont know, how far a empty format can help you. Use a empty fromat in case of DXF or DWG.
