Hi Greg, Right now I m not infront of my computer which has seat for Pro/E. I will try modeling your example tomorrow and would suggest you what is to be done next. In the meantime you may try running MPA. I hope you have defined free inteface to avoid node merging. This has worked well so far for most of my cases. If you run into more problems then there is a way to do it in independent mode, where you mesh the parts seperately, then translate them back to assemble in the interference state. Thereafter, rerun the above analysis.
