Multi model Drawing
sjawale-2
2-Explorer
Multi model Drawing
Hello all
I have one old multi model drawing with 7-8 different models but only with small geometry changes.
My question is how can i check which view is of which part model?
the only way i know is set one model.. select a view if the model name in tree highlighted its the view with that model
is there any other easy way?
Right click the view in Drawing (or in Drawing Tree) and choose View Info -> the view model is listed.
6 REPLIES 6
Right Click on the view and select "Use Model in tree" and that model is activated in the model tree.
Sachin,
Did you get the answer of your query from any of the replies in the post? If yes, you may mark appropriate reply as correct answer.
Timmo, Manjunath,
Your answers are interessant and show good tips. But this goal is not the answer i hope. No possibilities with "One click" to regenerate all the models in a multi-model drawing ?
Laurent, your question was discussed in another thread Multi-model drawings
ldrutel
(To:TimoNurmi)
Thanks you, Now it's clear for me.
