Good Day All,
As far as I can tell it's not possible to do batch analysis when in Pro/E (Creo) Mechanism?
Trying to run multiple mechanism analyses on one assembly and using multiple simplified reps.
Would like to set the mechanism analysis up so they are run automatically by distributed batch or the way Pro/E Mechanica (Simulate) runs in batch mode.
I have multiple analyses that take either several hours to run or days and would like to set it up walk away and just let them run.
I would also like to automate the process of saving off the measurement graph data to excel format along with an mpeg movie file for each analysis.
Anyone have any ideas?
Thanks for any help you can throw my way,
Don Anderson
See Product Idea
http://communities.ptc.com/ideas/3637
If link does not work search for:
Batch Mechanism Analysis - Like Mechanica/Simulate
See Product Idea
