I want to display a model parameter on an assembly drawing.
I know that I can display the parameter by adding the note: ¶meter.
But because the model is an assembly I have to add a number behind it if I want to display a parameter of a model in the assembly structure. like: ¶meter:<number>.
How can I find out which number I have to use for which model in the assembly structure?
(At this moment I am doing it with trail and error 😞 )
I know that I can display the parameter by adding the note: ¶meter.But because the model is an assembly I have to add a number behind it if I want to display a parameter of a model in the assembly structure. like: ¶meter:<number>.
please read https://community.ptc.com/t5/3D-Part-Assembly-Design/Session-id/m-p/67625#M12249 discussion.
... I found the above info using https://www.ptc.com/en/support/search page and searching for session id string.
Thanks: this was very helpful.
regards,
Bert
