Did you find a solution to this?
I'm experiencing the exact same situation .
RE: post
... to fill MODEL_NAME parameter with model name , one have to define relation
model_name=rel_model_name
RE: post
MODEL_NAME parameter must exist in the model to which the annotation is attached.
This worked, thank you.
@MtnsRCalling I think that thread got messy because two threads were combined into one.
I never did find a solution, so I had to make the note manually and just pay attention to it if things changed. It was strange that I couldn't get that particular parameter to work.
