Parameters and Relations
ptc-5924
Is there a better way to add parameters and layers into imported vendor files and existing part/assy files.
If you add a text file into relations that works, but not to existing files. Can this be setup in model check.
Evan
We have two main mapkey's set up for this. It works well. The only thing is you have to make sure you don't hit the key more than once, that will cause duplicate parameters. mb
