Parasolid export - units in mm?
pgibson
Hi - is there a way of making the default units saving to Parasolid files in millimetres as opposed to metres?
Pete.
BenLoosli
(To:pgibson)
I don't think so since the default unit in Parasolids is the meter.
By using the meter as the default, it allows them to model larger models before running out of digits in a number. 32768 meters is a lot larger than 32768mm!
We used to ask the same question on the UG/NX side and that was their answer. Since they own the Parasolids kernel, they should know.
