Part Family table create drawing
AS_8412631
2-Explorer
Hello
I create a part with a drawing
I create a familly table and would like a drawing for each instance
Does it possible to create this drawings  automaticaly?
Thanks for your reply
tbraxton
(To:AS_8412631)
Yes, but it requires some upfront work to create the drawing templates with the required elements.
If you are asking is there an out of the box Creo function to automatically create drawings by only referencing a model, the answer is no.
Involute Development, LLC
Consulting Engineers
6 REPLIES 6
tbraxton
(To:AS_8412631)
"If you are asking is there an out of the box Creo function to automatically create drawings by only referencing a model, the answer is no."👍
BR84
(To:AS_8412631)
Create a mapkey to create a drawing of a part and run this mapkey, on instances of selected parts in distributed batch.
I have something like that for creating dxf files with flat views of the selected instances and it works great.
However, I still have to put it through the distributed batch.
AS_8412631
2-Explorer
(To:BR84)
Thanks for your reply I will try with mapkey
BR84
(To:AS_8412631)
Try please try my code:
  • 4 mapkeys, trail file
  • to make it work you have to modify it - template files, trail file location, and so on
Godspeed
RPN
(To:AS_8412631)
Yes, there is no button to do this.
But you don‘t need any special Drawing Template.
Just replace the drawing model by the requested instance. You can do this before you had copied the drawing, or do it after 😉
If you have now have some programming know how, read the family table instance information and write a loop via mapkeys or trail file. That’s it!
In Tcl less than 40 lines of code.
Have Fun!
