Part file missing/invisible in assembly
MarkGuisinger
I am a fairly new user and have been modifying and updating some drawings for my company. I have a large assembly that has some part files inserted into it. The part files are showing red in the model tree and actually are not visible in the assembly model. When I right click and open the part file for that item, there is no model. Working with WF5. Any help would be appreciated.
Mark,
WF5 doesn't know where missing files are located. Set SEARCH_PATH config.pro option to directory path where missing files are saved. You can also open missing files explicitly before you open the assembly.
Martin
Martin Hanák
