All,
Posting for any ideas on what application I should use for a particular use case.
End Solution:
A tube/piping part with multiple bends that has a small section of the pipe flattened to a certain depth (D shaped) and at a certain angle to the axis. Can be located anywhere along entire pipe.
1. Piping?
2. Sheetmetal?
3. Surfacing?
4. Solid Extrude?
5. Develop a UDF?
Has anyone had something similar that can share a design tip?
Thanks in advance.
