Preselection highlight selecting items in background
jskraba
I've noticed the issue some time ago, now I would like to find a solution for it. Namely, in Creo 2 M250 (also in older releases) when I hover with mouse over the drawing, preselection highlight is ALWAYS highlighting items, that are in the background. Since I've setup the view not to show items in background by using X-section and Z-clipping I obviously I'm not interested in background items. When I want to select any item with General filter on, shown in the foreground, Creo highlights items in background first. Why on Earth I would want items in the background to be highlighted when I specifically set up the view to show only items I'm interested in. See example below. I would like to select the blue line, shown in the foreground. When I hover over this blue line, some line in the background is prehighlighted?!? Now, if I would like to select the blue line, I need to select it by using Query Select. However, when query select list is shown, there are items listed first that are in the background!
How may I improve prehighlighting for the items that are actually in the foreground to be highlighted first and then items in the background? Is there any setting for this?
0 REPLIES 0
