"Gregory Woughter" wrote:
I've just been editing Detail to say VIEW, so I can't help much. I have a question about the same area. I want my Details to have a label that's VIEW A, but I want the A to be larger and a different font. I would have sworn I used to fix this in text edit under properties, but I can't seem to get a piece of text that carries two separate format values any longer. I've just been editing there as well, which isn't the right way. Sorry I'm not much help.
"Kevin Demarco" wrote:
Atleast for now I don't think you will find a setting that will change DETAIL to VIEW. Although it doesn't say a detail view has to be identified DETAIL 'X' the accepted practiced with the standards that are listed is DETAIL is used with detail views and VIEW is used with projection views.
