Pro/E WF2.0: Datum Curve: Variable pitch helical spring
anup.more
How can you make a helical spring with variable pitch values through
datum curves command? Is it possible? If yes, then what will be the
equations..??
Thanking you in advance
Anup More
Engineer- CAD
Emerson Climate Technologies (India) Limited
equations..??
Anup More
Engineer- CAD
This has reference to the mail below.
I'm sending you the attachment of the required spring type.
Anup More | T +91 2164 241 413 (2126) | M +91 9767 899 779
Create a datum curve described an equation. Choose the coordinate system
and choose Cylindrical as the type. Then have an equation like
! setting the radius of the helical spring
r = 5
! setting the spring to have 10 turns of 360º
theta = t*360*10
! setting the pitch of the spring so that the spring starts 1 mm from the
xy plane, ends 3 mm from the xy plane with an increasing pitch (first turn
is at z = 1.02, second turn at 1.08, third turn at 1.18, etc. You can
write any equation in here to get the pitch you want.
z = 1 + 2*t^2
Note that 't' is a ProE variable is equal to 0 at the start of the curve
and 1 at the end. At least one of the equations has to be written in terms
of 't'.
Mark von Huben
Anup,
been awhile since I've worked in wf2. in wf3 you can get the spring quite easily
with a variable helical sweep feature and choosing the pitch to be variable.
here is a sample image and part
Mark
