I have been told that it is going to be a nightmare storing the data in intralink created by the piping program due to the object not existing until you make it on the fly using the piping program. In my mind when you check it in it should grab all of the filed needed to complete the .drw/.asm. We have since went into panic mode here for a reason that I see to be unnecessary. If anyone can please adviseon how intralink stores the piping data in the assembly and able to make changes within the workspacein a manner that will remain intact,this would be most helpful.
