Hello ProE gurus,
I have a client for whichwe design handheld electronic products. We create the mechanical design, which includes parts like the housings for the product. We collaborate with them on the PCB design. Many time they ask us to provide them with a board outline, keepouts, etc... Our current process is to save out a .dxf file and provide them with a dimensioned .pdf file and any jpegs for clarification. They have been having problems importing the .dxf file into their program, and end up having to redraw the board outline from the provided .pdf file. As you can imagine this opens many possibilities for errors which makes the pocess take longer. Does anyone have a solution to a similar problem?
We are currently using WF4.0 and we do not use any other PTC product like Windchill or ProductView. We only have the what I believe to be the standard modules in the foundations package plus ISDX and Mechanica. I am hoping for a solution which does not require a significant cost.
My client is using Mentor Graphics PADDS.
Thank you for taking the time to read this.
Casey Stahl
Thank you to all those who have helped thus far. This is still an active issue. We have gotten busy and I haven't had much time to dedicate to the problem but here is the current status.
We have sucessfully exported a board shape to PADDS but none of the keepouts are showing up when our client opens the IDF3 file. Originally the keepouts had no depth, then we tried them with depth as well. We also tried just sketches.
Ideally we would like to export the board from ProE with the components whose locations are mechanically revavent.
Thank you in advance for any additional input.
