La última semana se instaló la última actualización del PTC Creo en el departamento de diseño mecánico de la empresa.
Hasta ese momento yo era capaz de ver los diseños generados con PTC Creo con mi PTC Creo Viewer express, pero a partir de ese momento no he sido capaz de ver ningún plano de conjunto (si las piezas sueltas).
Se trata de un bug?
He de realizar alguna otra acción?, probé a descargarme nuevamente la última versión del visor y tampoco fuí capaz.
GRACIAS
Hay una manera.
I want to bump this post so others can take another look at it.
It sounds like your company recently updated Creo and now you're no longer able to view drawings with Creo View Express as you did previously. Is this correct?
Please clarify:
Thanks Clint,
I'm gonna try to explain myself in a better way!
Yes it is!, before the last update of Creo I was able to open all the assemblies with my Creo View Express, but since this moment I didn't. I answer your two queries.
- The mechanical engineer sends me all the design into a folder and the files remains in the same place after opening. (I don't understand exactly what you mean)
- There isn't any error message after the opening, and it appears a screen like this.
(detail)
After this, I've tried to activate the box (next to the assembly name) to see the drawing and it doesn't work.
Hay una manera.
Muchas Gracias Rubén,
Tu recomendación funcinó sin problemas, eres un crack!!
Un abrazo
Genial!
Ten en cuenta que si trabajas con esqueletos, entonces este metodo no funcionará.
Saludos!
Speaking about the update, all the problem appears when we updated to Creo 3.0 040.
Thank you!
