Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
For me it says "Failed to load the file. May be Acrobat is not installed". But, then the document opens in an external Acrobat Reader window. It would be nice to open it directly in PV and save annotations to it.
Are you launching the PDF from the integrated browser on a x64 platform?
We ran into this issue as well. From what I found, it is caused by the x64 version of Product View launching the x86 version of Adobe Reader. Unfortionalty, there is not a x64 version of Adobe Reader.
To my knowledge, in order to make and save annotations to the PDF file, you need to be running Adobe Standard or Professional, which a x64 version is available.
Yep, It is a 64x machine. Thanks
For this type of issue/warning, the below workaround might get work done.
Edit->Preferences->Internet->
under Web Browser Options, check the box beside Display PDF in browser
This might solve your problem.
Just try uninstalling the "Document Viewing Option" from your Control Panel>#Add or Remove Programs
It might because when you installing the Productview, you select the "PDF collaboration Option", it should not be selected if you using Adobe Reader
Hi all,
pls check,
I have below configuration :
