Product idea - Pro/program : accept coma
Yannick_M
6-Contributor
PTC C11627128
Pro/ENGINEER and Creo Elements/Pro: Decimal Symbol comma "," is not accepted if you use an external text file with Pro/Program to regenerate the model.
Example :
In Pro/Program :
INPUT
DIMENSION number
END INPUT
In the external text file :
DIMENSION=12,9
The parameter will not be understood because there is a coma "," and not a point "."
The only solution is to modify Windows language parameters in order to modify the decimal symbol.
It should be better that Pro/ENGINEER automatically understand windows decimal configuration.
0 REPLIES 0
