Question on internal PDF creation using WF4
BrentDrysdale
7-Bedrock
Hi Folks,
I have been working to move us from WF4 M070 (where internal PDF creation crashes ProE) to a later version. I thought this would be M100 but the reported measure problems for large assemblies puts me off and we will probably go for M092 instead.
Which leads me on to actual testing of said PDF creation. The process is simple and I plan to just accept the defaults.
Once I had the pen_table_file thing sorted out I get mostly what I want.
Default of True Type fonts gives a very readable drawing compared to the old simulated stencil font (who remembers those days of manual lettering with a pen!!!)I get the tangent edges showing as grey lines with the hard edges as dark lines and this is close to right.
The big problem with this later setting is that I get edge on radii showing up as much thicker black lines (about twice as thick). On the screen the ProE drawing itself these lines are made up of raster steps and maybe that is the problem. Do not see this effect when using a virtual printer PDF creator.
I have attached a PDF of a subsection of a drawing that shows this effect.
I look forward to your comments.
Regards, Brent Drysdale
Mechanical Designer
Tait Electronics Ltd (www.taitworld.com)
New Zealand
Ph. +64 3 358 1093
This email, including any attachments, is only for the intended addressee. It is subject to copyright, confidential and may be the subject of legal or other privilege, none of which is waived or lost by reason of this transmission. If the receiver is not the intended addressee, please accept our apologies, notify us by return, delete all copies and perform no other act on the email. Unfortunately, we cannot warrant that the email has not been altered or corrupted during transmission.
0 REPLIES 0
